When I got back from school and started up my pc and when it was starting it got stuck on windows 7 logo
When I got into advanced menu and I clicked "Repair PC" it loaded something and again got stuck in black screen
And when I was trying booting up with safe mode it got stuck on "Loading Windows Files" :/
Oh godd please some1 help and tell if that problem is fatal or something
https://linustechtips.com/topic/941299-i-need-help/
Did you wait for it to load the Windows files after it got stuck? What are your PC specs? Also, please calm down, everything will be alright.
mechanical keyboard switches aficionado & hi-fi audio enthusiast
switch reviews  how i lube mx-style keyboard switches
https://linustechtips.com/topic/941299-i-need-help/#findComment-11475192
Yes I waited about 10 minutes but nothing :/
Well my specs are:
Cpu: pentium g870
8 GB Ram
Video card : Geforce 8600 Gt
And The Computer is branded as Fujitsu
https://linustechtips.com/topic/941299-i-need-help/#findComment-11475201
Aww, that's a shame, I'm sorry to hear.
I would recommend unplugging your video card and using your motherboard's input to isolate if it's your graphics card.
https://linustechtips.com/topic/941299-i-need-help/#findComment-11475275
