Lookup how to do a power drain.
Basically remove the battery if you can, or the equivalent which is a paperclip in the tiny hole on the bottom which will be marked.
Then plug back in and turn on.
Probably gaming or helping technophobes with tech...
https://linustechtips.com/topic/941189-laptop-not-starting-up/#findComment-11474183
I've tried this
I've tried before coming here, it did not work.
https://linustechtips.com/topic/941189-laptop-not-starting-up/#findComment-11474193
