[Help] Gaming PC Build
Solved by brownninja97,
~260 euros for the GPU, mine costs now 212 euros.
In-store R9 series: http://www.mindfactory.de/Hardware/Grafikkarten+%28VGA%...
In-store GTX series: http://www.mindfactory.de/Hardware/Grafikkarten+%28VGA%...
Your best bet is to stay with the current gpu that you are getting, its quite a monster of a gpu anyways. Maybe you could get another keyboard or mouse with the money you are saving or just buy games whichever suits your fancy.
