10 C temperature difference between cores
Go to solution Solved by JamesBurgundy,
Update: Replaced the thermal compound with Deepcool Z5, temps dropped by 10C on all cores, no more throttling under AIDA 64 Stress test. Will replace with better compound soon. CPU now reaches 3.2-3.4Ghz, warranty isn't voided I think as there were no "VOID IF REMOVED" stickers
Hey guys,
So, I recently brought a new laptop, ASUS FX 553VD . Its the cheapest laptop with GTX 1050 on Amazon IN. My model has an Intel i5 7300HQ inside. I noticed that the temperatures reach 85 C while playing GTA 5. So, I ran AIDA 64 stress test on CPU and found out that the laptop is thermal throttling upto 25% under the test, which I assume is normal for a laptop.
The weird thing is Core #1 and Core #3 reaches only 68-70C, Core #2 82-84C and Core #4 reaches 85-87C under stress test.
Is it normal for there to be more than 10C difference between highest temp core and lowest temp core?
I haven't overclocked any part of this laptop.
Here is my AIDA 64 graph thingy.
==vFmdH1npbZ6PwRT2mQOGutuP3YBPHGvkcIeOximPMDcb7J4/0QDOrFIaXSrSE5DuEZ750w/PS5kLUjTDL3P+gjflJB7iUPDq7rgJTiZn2L5XK98dDMPYyfKrHVvvzkY0
https://linustechtips.com/topic/940608-10-c-temperature-difference-between-cores/
Asus laptops have shit stock paste so what do you expect. Moreover FX553 is very mediocre
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
38 minutes ago, JamesBurgundy said:
NT-H1
Will dry out fast in laptops due to low heatsink mounting pressure. I would suggest Gelid GC Extreme
Desktop specs:
Edited by JamesBurgundy
added note
Also do undervolting.
Desktop specs:
