1 minute ago, alan101 said:
what is a good quality PSU? I want one that is 1,000watts that can handle two 1080ti's in SLI. I honestly haven't really shopped for these that much so any advice will help.
Corsair and EVGA have been my PSU brands of choice.  In that Wattage all the models they make are quality items with good warranties.
https://linustechtips.com/topic/939900-psu-help/#findComment-11463208
For me as well. I never use and never recommend any other brands.
@alan101 I would suggest the EVGA SuperNOVA 1000 G2, 80+ Gold 1000 W: https://www.evga.com/products/product.aspx?pn=120-g2-1000-xr
https://linustechtips.com/topic/939900-psu-help/#findComment-11463221
1 minute ago, Christophe Corazza said:
For me as well. I never use and never recommend any other brand.
This may seem like a dumb question so sorry in advance but how can you tell how many GPU's a PSU will support?
https://linustechtips.com/topic/939900-psu-help/#findComment-11463226
Insanity is not the absence of sanity, but the willingness to ignore it for a purpose. Chaos is the result of this choice. I relish in both.
https://linustechtips.com/topic/939900-psu-help/#findComment-11463228
I may be wrong on this, but i'm guessing any 1000W PSU worth it's salt will have enough spots for 2 gpus. Now if you're doing a 10 GPU mining rig, probably need to do some more research, but with just 2, you should be fine
https://linustechtips.com/topic/939900-psu-help/#findComment-11463232
Depending on the manufacturer, one 1080 Ti needs either one 8 pin and one 6 pin power connector or two 8 pin power connectors.
Therefore two 1080 Tis needs either two 8 pin and two 6 pin power connectors or four 8 pin power connectors.
Next, check the power consumtion of your card. A FE 1080 Ti at idle draws 13 W, but this can increase rapidly with more demanding tasks: https://www.tomshardware.com/reviews/nvidia-geforce-gtx-1080-ti,4972-6.html
So, verify the amount of connectors available on your PSU and also the amount of current each rail of your PSU can provide. :)
https://linustechtips.com/topic/939900-psu-help/#findComment-11463332
