VB - Help sending data to URI
Go to solution Solved by BeefyMeats,
I found the old post that was used before and its working now.
Here it is: https://stackoverflow.com/questions/4015324/how-to-make-http-post-web-request
Useless info:
I made (copy/pasta alot of code until it worked) a site some time ago to toggle things at home, and an app to toggle them without a web browser but dont have the source anymore. My old app still works, but I need to add one more device to toggle. (no source for it anymore)
Useful info:
I need to send this data to toggle the device, and have code that seems like it would work, but im not sure how to store it in a variable that would work with the function
Need to send this:
{ "outletId", "1" },
{ "outletStatus", "on" }
Heres the code I have so far:
Thanks!
Imports System.IO
Imports System.Net
Imports System.Net.Http
Imports Newtonsoft.Json.JsonConvert
Imports Newtonsoft.Json.Linq
Imports Newtonsoft.Json.JsonSerializer
Imports System.Net.Http.Formatting
Public Class Form1
    Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click
        Dim Uri As String = "http://thing/toggle.php"
        'somehow use data here :)
        SendRequest(Uri, Data, "text/json", "POST") 'application/json
    End Sub
    Private Function SendRequest(uri As Uri, jsonDataBytes As Byte(), contentType As String, method As String) As String
        Dim req As WebRequest = WebRequest.Create(uri)
        req.ContentType = contentType
        req.Method = method
        req.ContentLength = jsonDataBytes.Length
        Dim stream = req.GetRequestStream()
        stream.Write(jsonDataBytes, 0, jsonDataBytes.Length)
        stream.Close()
        Dim response = req.GetResponse().GetResponseStream()
        Dim reader As New StreamReader(response)
        Dim res = reader.ReadToEnd()
        reader.Close()
        response.Close()
        Return res
    End Function
End Class
---- edit ----
Here is what was suggested to use. Any idea how to use it properly with the data I have?
Dim data = Encoding.UTF8.GetBytes(jsonSring)
Dim result_post = SendRequest(uri, data, "application/json", "POST")
https://linustechtips.com/topic/939766-vb-help-sending-data-to-uri/
Because I dont know what Im doing, and just keep hammering in code from Google until my projects work.
------edit --------
this is what I used, not sure what the difference is, but what was used in button1 seems to be "snappier/quicker"
I attempted to use what you suggested for button2, and it also works. Thanks
Imports System.IO
Imports System.Net
Imports System.Text
Public Class Form1
    Private Shared ReadOnly httpClient As HttpClient = New HttpClient()
    Private Async Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click
        If True Then
            Dim url As String = "http://thing/toggle.php"
            Dim values = New Dictionary(Of String, String) From {
                {"outletId", "2"},
                {"outletStatus", "off"}
            Dim content = New FormUrlEncodedContent(values)
            Dim response = Await httpClient.PostAsync(url, content)
            Dim responseString = Await response.Content.ReadAsStringAsync()
        End If
    End Sub
    Private Async Sub Button2_Click(sender As Object, e As EventArgs) Handles Button2.Click
        Dim Data = New Dictionary(Of String, String) From {
                {"outletId", "2"},
                {"outletStatus", "on"}
        Dim httpContent = New FormUrlEncodedContent(Data)
        Dim asdf = Await httpClient.PostAsJsonAsync(url, httpContent)
        Dim response = httpClient.PostAsync(url, httpContent).Result
    End Sub
End Class
