32 minutes ago, maxlovetoby said:
Hey, i was just wondering before linus got that big UPS what were the old ones that they used in the moving vlog? Just want to know
They had GE UPS units that they kept beside their editing stations including ones in the server before the large Eaton one.
@13 mins
Edited by W-L
https://linustechtips.com/topic/939689-ups-question/#findComment-11460847
They used refurbished GE ones that I believe gave them issues so they stopped using them.
If you're looking to buy some, I'd recommend cyberpower (bang for the buck), Eaton (my fave now personally), or APC.
https://linustechtips.com/topic/939689-ups-question/#findComment-11460850
