my build that im ordering parts on is below. Everyone will have there opinions on certain things. My question is will a Radeon RX Vega 56 be compatible with this build? What is the RX Vega 56 equivalent to in terms of Nvidia cards (i am only familiar with Nvidia).
PCPartPicker part list: https://pcpartpicker.com/list/FC8FZR
Price breakdown by merchant: https://pcpartpicker.com/list/FC8FZR/by_merchant/
CPU: Intel - Core i7-8700K 3.7GHz 6-Core Processor  ($339.99 @ Best Buy)
CPU Cooler: CRYORIG - H7 49.0 CFM CPU Cooler  ($34.99 @ Amazon)
Motherboard: Asus - Prime Z370-A ATX LGA1151 Motherboard  ($162.20 @ OutletPC)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory  ($159.99 @ Newegg Business)
Storage: Crucial - MX500 250GB 2.5" Solid State Drive  ($69.99 @ Adorama)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($57.99 @ Amazon)
Video Card: MSI - GeForce GTX 1060 6GB 6GB GAMING X Video Card  ($314.99 @ Newegg)
Case: Fractal Design - Meshify C Dark TG ATX Mid Tower Case  ($88.99 @ SuperBiiz)
Power Supply: EVGA - SuperNOVA G3 850W 80+ Gold Certified Fully-Modular ATX Power Supply  ($99.99 @ Amazon)
Total: $1329.12
Generated by PCPartPicker 2018-06-19 18:00 EDT-0400
Thank you to all who reply
https://linustechtips.com/topic/939315-question-regarding-a-graphics-card/
The Vega 56 is between a 1070 and 1070 Ti
CPU: Core i9 12900K || CPU COOLER : Corsair H100i Pro XT || MOBO : ASUS Prime Z690 PLUS D4 || GPU: PowerColor RX 6800XT Red Dragon || RAM: 4x8GB Corsair Vengeance (3200) || SSDs: Samsung 970 Evo 250GB (Boot), Crucial P2 1TB, Crucial MX500 1TB (x2), Samsung 850 EVO 1TB || PSU: Corsair RM850 || CASE: Fractal Design Meshify C Mini || MONITOR: Acer Predator X34A (1440p 100hz), HP 27yh (1080p 60hz) || KEYBOARD: GameSir GK300 || MOUSE: Logitech G502 Hero || AUDIO: Bose QC35 II || CASE FANS : 2x Corsair ML140, 1x BeQuiet SilentWings 3 120 ||
LAPTOP: Dell XPS 15 7590
TABLET: iPad Pro
PHONE: Galaxy S9
She/they
Total: $1329.12
I forgot to mention but if you can find a lower wattage psu for less you should consider that option but if you’re planning to overclock or something then 850w is fine even though it’s still a bit much imo. You might also want to invest in a better cooler because 8700k is known to get quite hot as well from what I’ve seen on forums.
poop
V56 is a GTX 1070, in AMD sponsored titles using DX12 you can call it a 1070 Ti...
Yes it would be compatible but you'd be better off with a 1070 Ti or even a 1080 Ti if you can afford it, I mean the whole build aside that lame 1060 is super high end and can comport any GPU you want.
Personal Desktop":
Luna, the temporary Desktop:
As long as the motherboard has a full PCIe 16x slot, any modern GPU will be compatible. The RX Vega series of GPUs I don't know too much about, but I'm fairly certain the Vega 56 cards are between 1070 and 1070 Ti, whereas Vega 64 is between 1070 Ti and 1080
Primary PC: - https://pcpartpicker.com/list/8G3tXv (Windows 10 Home)
HTPC: - https://pcpartpicker.com/list/KdBb4n (Windows 10 Home)
Server: Dell Precision T7500 - Dual Xeon X5660's, 44GB ECC DDR3, Dell Nvidia GTX 645 (Windows Server 2019 Standard)
*SLI Rig* - i7-920, MSI-X58 Platinum SLI, 12GB DDR3, Dual EVGA GTX 260 Core 216 in SLI - https://pcpartpicker.com/list/GHw6vW (Windows 7 Pro)
HP DC7900 - Core 2 Duo E8400, 4GB DDR2, Nvidia GeForce 8600 GT (Windows Vista)
Compaq Presario 5000 - Pentium 4 1.7Ghz, 1.7GB SDR, PowerColor Radeon 9600 Pro (Windows XP x86 Pro)
Compaq Presario 8772 - Pentium MMX 200Mhz, 48MB PC66, 6GB Quantum HDD, "8GB" HP SATA SSD adapted to IDE (Windows 98 SE)
Asus M32AD - Intel i3-4170, 8GB DDR3, 250GB Seagate 2.5" HDD (converting to SSD soon), EVGA GeForce GTS 250, OEM 350W PSU (Windows 10 Core)
*Haswell Tower* https://pcpartpicker.com/list/3vw6vW (Windows 10 Home)
*ITX Box* - https://pcpartpicker.com/list/r36s6R (Windows 10 Education)
Dell Dimension XPS B800 - Pentium 3 800Mhz, RDRAM
In progress projects:
*Skylake Tower* - Pentium G4400, Asus H110
*Trash Can* - AMD A4-6300
*GPU Test Bench*
*Pfsense router* - Pentium G3220, Asrock H97m Pro A4, 4GB DDR3
could i do water cooling with the case i have?
