Internal USB 3.0 Hub like the NZXT Usb 2.0 Hub?
sivasunken
I bought a ASUS ROG Maximus X Formula MB and a Cooler Master C700P Case. However the front Panel Connectors for the case has 2 USB 3.0 cable. However my motherboard has only 1 Usb 3.1 Header that i can connect to. Is there a Usb 3.0 splittter cable or an Internal USB 3.0 Hub like the NZXT Internal Hub that i can use to connect both the cables?
Thanks in Advance
I think this is what you're looking for: A USB 3.0 20-Pin Female to 2x USB 3.0 20-Pin Male Y Adapter. They are pretty uncommon, but here's a link to an online store selling it.
http://www.frozencpu.com/products/22397/ele-1275/USB30_20-Pin_Female_to_2x_USB30_20-Pin_Male_Y_Adapter.html
If you want to keep things simpler, you can always get a USB 2.0 to USB 3.0 Adapter, but you'll get 2.0 performance.
https://www.amazon.com/SIENOC-Female-Motherboard-Housing-Adapter/dp/B00EOI3VC8/ref=sr_1_3?s=electronics&ie=UTF8&qid=1529330283&sr=1-3&keywords=usb+2.0+to+3.0
It's weird a board such as the Maximus doesn't have 2x USB 3.0 but my friends MSI B350 board does? I'd definitely -1 star the Board in a Review because of that.
CM could also have put all the USB 3.0 in one header instead...
RGB & Fan control ULTIMATE GUIDE !
  • 3 months later...
