Hello
I just got offered 3 pc's (They can still be modified).
We mainly use:
3Dmax (mental ray cpu based)
Illustrator
Photoshop
Indesign
Autocad
Vectorworks
PC #1(prebuilt)
HP Workstation Z240 serie € 1.699,00 € 1.699,00
Intel Core i7 processor 6700
16 GB geheugen
1 TB SSD
NVIDIA videokaart met 2 GB grafisch geheugen Quadro k620 2gb
DVD-ROM speler
Windows 10 Professional 64bit Nederlands
PC#2 €1081
1x TQXSB5 Sharkoon S1000                      mATX
1x GNIR21 Asro B360M PRO4                     B360
1x HN5I05 Intel Core i5−8500    3000 1151V2 BOX
1x IEIGCN2D D4 16GB 2666−16 BX Sport LT    gy K2 CRU
1x IMJM4Y SSD 500GB  530/550 860 EVOBasic  SA3 SAM
1x JFXR04 PNY 5GB D5 X Quadro P2000
1x YOBMJH06 MS Windows 10 Pro               64bit NL
PC#3 €1750
375054 Fractal Design Define R5 Black 1 86.74 104.95 104.95
209532 Moederbord Intel Asus PRIME Z370-P 1 98.35 119.00 119.00
271245 Processor Intel Core i7 8086K 1 371.07 449.00 449.00
377289 CoolerMaster CPU Cooler Hyper TX3 Evo 1 22.95 22.95
351410 Corsair DDR4 Vengeance LPX 2x16GB 2666 C16 1 304.96 369.00 369.00
229628 Samsung SSD 970 EVO 500GB 1 147.93 179.00 179.00
951977 WD HDD 3.5" 1TB S-ATA3 64MB WD1003FZEX Black 1 65.25 78.95 78.95
994017 VGA MSI GeForce GTX 1050 TI 4GT OC 1 156.20 189.00 189.00
999192 Corsair PSU CX650 Bronze 1 53.68 64.95 64.95
955260 Microsoft Windows 10 Home 64bit NL OEM 1 99.13
What would be best?
And does a quadro improve preformance of a render enginge that does not use the GPU? (Currently using a GTX960)
The current PC I use is a
i74790 3.60ghz
16gb ram
GTX960
Thanks
https://linustechtips.com/topic/938807-need-help-with-a-build/
Usually they help a fair bit with CAD, but in other things like video editing they're kinda useless. That being said, in AutoCAD the speedup doesn't seem to justify the increase in price, from what I've seen, so I think a geforce would be adequate.
6 minutes ago, RJ87 said:
Sorry, the price was wrong. its €1081 on PC2.
Changed it.
Would you reccomend changing it to an i7 and up the ram to 32gb? Or is 16 plenty.
Change the gpu to something like a 1050 ti on that build and upgrade to an i7 8700.
Just a question though, where's the psu on pc2?
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
https://linustechtips.com/topic/938807-need-help-with-a-build/#findComment-11452652
The i7-6700 is two generations back with a max turbo of 4GHz.
The i7-8086 is not worth its added cost. The 5GHz clock is pretty much pure marketing hype. With any sort of load, the cpu performs like an i7-8700K.
Vectorworks and Mental Ray can benefit from more cpu power so #2 with and i7-8700 would be a good choice. The cpu has a higher clock than the i5-8500 at any given load which means better performance. The i7-8700 turbo clocks are just 100MHz under the i7-8700K so the stock performance difference is quite small. The lower base clock results in less power consumption at idle, slightly lowering running costs.
If the work involves reasonably large projects, 32GB of memory can improve performance.
Autodesk 3Ds Max certifies Quadro gpu. While it does test Geforce models, direct support is going to be better with a Quadro. Given models of any complexity, a P4000 would likely provide a better viewport experience than the P2000.
A reliable 450W or 550W psu is required.
https://linustechtips.com/topic/938807-need-help-with-a-build/#findComment-11452812
