I'm currently using a Coolermaster Master air heatsink for my intel 4790k. Basically my issue is that its too big and it seems like its not really cooling my CPU very well like my old deepcool aio. I was considering the Cooler Master MasterLiquid 240 due to having a Coolermaster Maker 5 case.. The other option would be to go after a Corsair AIO or a Be Quiet Dark Rock TF.
https://linustechtips.com/topic/938330-cooler-master-masterliquid-240/
Don't get the Masterliquid. An air cooler of similar price or a more expensive AIO will outperform it.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
Performance should be about the same as any other 240mm AIO, build quality is borderline on them.
They're fine/cheap
Currently looks like the EVGA 240 is the way to go at $90
https://pcpartpicker.com/product/krZ2FT/evga-clc-240-748-cfm-liquid-cpu-cooler-400-hy-cl24-v1
4 minutes ago, Holmes2468 said:
What about the Corsair AIO?
Which one?
SPECS:
Corsair Hydro Series, H115i  abd replace fans with my 140mm Noctua fans
https://www.newegg.com/Product/Product.aspx?Item=N82E16835181138
or
Corsair Hydro Series, H150i
https://www.newegg.com/Product/Product.aspx?item=N82E16835181139
Corsair Hydro Series, H150i if I can get it to fit in my case
42 minutes ago, Holmes2468 said:
Either those or the EVGA CLC 280 Liquid that Streetguru recommended with the Noctua fans
So the EVGA 240 or 280...I'd get the 280.
SPECS:
So I ended up purchasing a Corsair H110i due to having gift certs at Bestbuy. Would it be overkill to run the radiator in a push pull config with 4 Noctua fans? I have it currently set up for push with the two Noctua Fans I currently have.
It can help maintain cooling if you're running the fans at very low rpm for low noise but is otherwise a waste of money.
I have the ML240L RGB, it's hard to beat at $50 but I can answer any Q's if you wanted background knowledge since you bought something else.
What temps are you getting with the push setup?
PC : 3600 · Crosshair VI WiFi · 2x16GB RGB 3200 · 1080Ti SC2 · 1TB WD SN750 · EVGA 1600G2 · Define C
