I have a 3570K overclocked to 4.4Ghz with some high voltage because of Vdroop and it gets pretty hot. I am cooling it with a Hyper 212+ with a fan that is not original and probably worse and its held on by elastics. My temps when at full load are hitting 90C and that's to hot for me so i was thinking of running a dual 120MM rad just for my CPU. What all do I need to have a loop for my CPU that will fit in a 300R. Also I'm on a budget so cheaper parts would be nice and I do want to use compression fittings even tho they cost more.
https://linustechtips.com/topic/9382-water-cooled-3570k/
Well, if you are on a budget and just want to cool that CPU - have you looked at an AiO unit? H100 or H100i? Not sure if a H110 would fit - but that be even better.
After looking around around, doesn't look like an H110 will fit - VERY tight.
Forum Links - Community Standards, Privacy Policy, FAQ, Features Suggestions, Bug and Issues.
Folding/Boinc Info - Check out the Folding and Boinc Section, read the Folding Install thread and the Folding FAQ. Info on Boinc is here. Don't forget to join team 223518. Check out other users Folding Rigs for ideas. Don't forget to follow the @LTTCompute for updates and other random posts about the various teams.
Follow me on Twitter for updates @Whaler_99
https://linustechtips.com/topic/9382-water-cooled-3570k/#findComment-103463
It should fit my case supports dual 140mm s at the top and its a corsair case so if i get a h110i i doubt i will have any problems but i am looking to get some experience in custom water cooling because i want to slowly upgrade my system to the point where water cooling makes sense.
https://linustechtips.com/topic/9382-water-cooled-3570k/#findComment-105652
