I've learned enough about the Nvidia control panel to figure out it's not as intuitive as you would think when it comes getting the highest scores while benchmarking. For example, if AF and AA are turned off then I get a lower score than if they are set to 'Application-Controlled'. You would think that having those off would lead to higher scores but it's the opposite. Also, Trilinear and AF optimizations lower scores too which you would think would be the opposite. The above is true regarding Firestrike, Timespy, and Passmark.
Has anyone figured out the optimal Nvidia control panel settings for benchmarking?
Setup // CPU: 7700k@5.0Ghz w/ H100i v2 // MB: MSI Z270 Gaming M5 // HDD: 1x500GB 960EVO 1x500GB 850EVO 2x4TB 7,200 Barracudas // RAM: 16GB 3000MHz Corsair Vengeance // GPU: ASUS GTX 1080 Turbo @ 2000MHz w/ NZXT G12 // PSU: 550W EVGA G2 // Case: Phanteks P400S TG
https://linustechtips.com/topic/937300-nvidia-control-settings-for-benchmarking/
