Hi i was wondering if anyone could help me decide on what to do with my water cooling setup.
I currently have the NZXT Noctis 450 case with a EK 360mm PE rad in the top of my case and a EK 120mm PE rad in the back with three fans in the front.
I was thinking of getting rid of the 120mm at the back and putting in a 360mm of the same type at the front instead so i'd have dual 360mm's (120mm has to go because of space in this scenario and only a slim fan could possibly fit there)
But i'm wondering if this would be beneficial at all seeing as i'd either be blowing warm radiator air through my case and into the second radiator or if i set both rads as exhaust or intake that i'd either be starving the fans of air or throwing all the rad heat into my case.
If i could get any advice that'd be great :)
Thanks.
https://linustechtips.com/topic/936986-need-rad-advice/
Don't worry about the warm air. it's only warmer by like 1c, so the second radiator will work fine.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/936986-need-rad-advice/#findComment-11436680
Rad exhaust is not very warm since the heat is so spread out. Although I would recommend leaving the 120mm rad's fan in the back of the case.
What is actually supposed to go here? Some people put their specs, others put random comments or remarks about themselves or others, and there are a few who put cryptic statements.
https://linustechtips.com/topic/936986-need-rad-advice/#findComment-11436681
