8 minutes ago, M.Yurizaki said:
Twitch caps the bitrate to 6 Mbps, so whatever quality you think looks good in that bitrate.
I stream using nvidia band it gives me the option to have a bitrate from 1-18. I want to stream at 720p 60fps what should I choose.
https://linustechtips.com/topic/936969-streaming-speed/#findComment-11436518
6 Mbps, because that's the most Twitch accepts. Whether or not 720p 60 FPS looks good or not depends on how much is going on. See:
https://linustechtips.com/topic/936969-streaming-speed/#findComment-11436524
