Q abode sub zero cooling
3 minutes ago, giftslayer said:ok so i could use something like silicon just silicon is harder to remove?
And also can prestik be used or is there something different from prestik and art eraser bc i dint find anething on the internet and prestik is cheaper that art eraser but i don't want to go and try prestik and it has something that will make it break up or something.
i think i manly want to know is whats so different from prestik and art eraser for me they feel the same but prestik is a lot cheaper here where i am.
If your referring to this it looks like it might work as it’s just a putty compound but only way to find out is testing. Main thing you don’t want is for it to delaminate from the surface due to temperature changes or weep out a grease or film which some sticky tact may do overtime.
https://www.bostik.com/southafrica/Bostik-Products/original_reusable_sticky_putty
You can use silicone I guess, before and even still now some like to use dielectric grease in the socket and around it to help with preventing condensation.
