4 hours ago, InsertFunnyNameHere said:
Hi guys! My cable broke off from my keyboard and I was wondering could it be replaced with any usb cable? Are the insides of the USB cables all the same?
what kind of usb is it? Usb mini, micro, typec? if your able to disconnect it from the keyboard just look for a cable that is for charging and data transfer
CPU: AMD Ryzen 9 5900HX GPU: AMD RX 6800M RAM: 16GB  SSD: 500GB NVME
https://linustechtips.com/topic/935887-usb-cables/#findComment-11427395
USB cables themselves are the same (apart from quality off course).
Do you mean soldering a new cable to your keyboard? That can be done depending on your soldering skills. What keyboard do you have? (Perhaps uploading some clear pictures of the damaged parts?)
https://linustechtips.com/topic/935887-usb-cables/#findComment-11429237
