I recently built a new PC and went with Ryzen, always been with Intel prior, and notice my PC is running rather hot on the outside. I used CoreTemp to see what my temps are and idle it sits at 50 (give or take a few degrees). What are normal temps to see idle on a Ryzen platform?
https://linustechtips.com/topic/935716-ryzen-7-2700-temps/
you must have your cooler mounted incorrectly, idle temps should be 30-40 at the most.
AMD Ryzen 5 3600 | Corsair H100i Pro | ASRock X570 Phantom Gaming 4 | Corsair Vengeance 32GB 2x16gb @ 3200mhz  | Vega 64 @ Stock | Fractal Design Define R4 | Corsair RM750
ThinkPad T480 | Intel Core i7 8650u | Nvidia MX150 | 32GB DDR4 @ 2400mhz | Samsung 840 Pro 1tb
https://linustechtips.com/topic/935716-ryzen-7-2700-temps/#findComment-11425493
also, make sure you're using something like ryzen master for the temps.
https://linustechtips.com/topic/935716-ryzen-7-2700-temps/#findComment-11425494
