Hi, everyone, I'm having problems with the EZPLUG connector of an asus rampage apex vi, when I plugged in the 7 molex chip from the source, the computer does not turn on, I have a seasonic of 850, two gtx 980 matrix, two ssd m.2 , 1 disc and coolers. What can cause the motherboard to short?
Video of problem : https://youtu.be/pJ9OLD3p_64
https://linustechtips.com/topic/934831-problemas-con-el-ezplug/
And if you disconnect that cable, does the board power up normally?
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
https://linustechtips.com/topic/934831-problemas-con-el-ezplug/#findComment-11416960
