My Dell E5400 finally died and I need a replacement.
What is the cheapest new thin and light laptop (or tablet) available?
Requirements:
- able to run windows/ Linux
- minimum 2 GB ram (4 or more preferably)
- descent battery life
- at least one USB A port
This will mainly be used for vehicle tuning
Apps include VCDS, tuner studio, etc.
System specs:
4790k
GTX 1050
16GB DDR3
Samsung evo SSD
a few HDD's
https://linustechtips.com/topic/934623-need-help-finding-a-laptop/
-Moved to Laptops and Pre-Built Systems-
Look at Facebook Marketplace, especially if you just want something cheap.
Generally you won't feel too bad breaking one if it comes down to it.
Otherwise, a used surface pro off ebay should do the trick (Just be sure that it is a working unit, as there are a lot of as-is/for parts units) for $100-200.
I'm sure there's some cheaper off-brand stuff if you're willing to tinker or put some research into it.
COMPUTER: Mobile Battlestation  |  CPU: INTEL I7-8700k |  Motherboard: Asus z370-i Strix Gaming  | GPU: EVGA GTX 1080 FTW ACX 3.0 | Cooler: Scythe Big Shuriken 2 Rev. b |  PSU: Corsair SF600 | HDD: Samsung 860 evo 1tb
Any links of online stores?
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
hp 840 g1 / g4 / g5
acer s7
hp folio
lenovo x1 carbon
razer 2014/2015
these are stock/ref
or new ones :
xiaomi mi notebook
asus vivobook
x1 carbon 2016/2017/2018
lenovo yoga
razer 2016/2017
you may use this too for new laptop finding:
https://noteb.com/?search/adv_search.php
Thanks for all the suggestions so far, I'm leaning towards a surface pro, as it seems to offer most of what i need.
unfortunately, my local classifieds are pretty barren and contain only overpriced apple stuff. I'm looking at ebay.
System specs:
4790k
GTX 1050
16GB DDR3
Samsung evo SSD
a few HDD's
