I wanted some feedback on this pc build I have thought about buying. I have a fixed budget of $1000 USD
PCPartPicker part list: https://pcpartpicker.com/list/V2w6QZ
Price breakdown by merchant: https://pcpartpicker.com/list/V2w6QZ/by_merchant/
CPU: AMD - Ryzen 3 2200G 3.5GHz Quad-Core Processor  ($94.99 @ SuperBiiz)
Thermal Compound: Innovation Cooling - Diamond "7 Carat" 1.5g Thermal Paste  ($7.85 @ OutletPC)
Motherboard: Asus - PRIME B350M-A/CSM Micro ATX AM4 Motherboard  ($78.48 @ OutletPC)
Memory: G.Skill - Aegis 16GB (1 x 16GB) DDR4-2133 Memory  ($165.99 @ Newegg)
Storage: Western Digital - Black PCIe 256GB M.2-2280 Solid State Drive  ($79.99 @ Amazon)
Storage: Western Digital - RE4 1TB 3.5" 7200RPM Internal Hard Drive  ($42.99 @ Amazon)
Video Card: MSI - Radeon RX 570 8GB ARMOR OC Video Card  ($289.99 @ Amazon)
Case: NZXT - S340 (White) ATX Mid Tower Case  ($59.99 @ SuperBiiz)
Power Supply: EVGA - SuperNOVA G3 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($69.99 @ Amazon)
Wireless Network Adapter: Gigabyte - GC-WB867D-I PCI-Express x1 802.11a/b/g/n/ac Wi-Fi Adapter  ($33.89 @ OutletPC)
Case Fan: Cooler Master - MasterFan Pro 120 Air Balance RGB (3 pack) w/RGB Controller 42.7 CFM  120mm Fans  ($39.99 @ Newegg)
Keyboard: Redragon - S101 Wired Gaming Keyboard w/Optical Mouse  ($29.99 @ Amazon)
Total: $994.13
Generated by PCPartPicker 2018-06-05 13:44 EDT-0400
https://linustechtips.com/topic/934561-first-pc-build/
It is a nice build but I would rather go ryzen 1600 instead of that 2200g. You will be using dedicated gpu so there is not point in going for apu. I would just give up e.g. rgb fans for now or that wifi adapter if u do not need it. Also you would do better with 2x8 gb rams... I suggest going atleast for 2666mhz I really do not think there is a huge price difference. You could get 3000mhz sticks for like ~170$ when I checked last time.
https://linustechtips.com/topic/934561-first-pc-build/#findComment-11414197
Total: $994.13
That board is pretty poor as it has no VRM cooling. Also an ATX board will look better in an ATX case.
No point getting thermal paste if you are using the stock cooler.
You want faster ram for Ryzen. Go with 2 x 8GB of 3000 - 3200.
I would get a cheaper SATA SSD such as the Team Group L5 or Crucial MX300 etc.
Strange choice of HDD. Just get a regular barracuda (Green label) or WD Blue etc.
The EVGA G3 has some issues I believe. Maybe swap it for something like a Seasonic Focus or Corsair RMx etc.
https://linustechtips.com/topic/934561-first-pc-build/#findComment-11414220
Is the thermal paste necessary? I think the coolers should come with a bit already.
Specs: Motherboard: Asus X470-PLUS TUF gaming (Yes I know it's poor but I wasn't informed) RAM: Corsair VENGEANCE® LPX DDR4 3200Mhz CL16-18-18-36 2x8GB
            CPU: Ryzen 9 5900X          Case: Antec P8     PSU: Corsair RM850x                        Cooler: Antec K240 with two Noctura Industrial PPC 3000 PWM
            Drives: Samsung 970 EVO plus 250GB, Micron 1100 2TB, Seagate ST4000DM000/1F2168 GPU: EVGA RTX 2080 ti Black edition
https://linustechtips.com/topic/934561-first-pc-build/#findComment-11414250
Total: $994.13
Build something like this...
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($174.88 @ OutletPC)
Motherboard: ASRock - X370 KILLER SLI/ac ATX AM4 Motherboard  ($123.88 @ OutletPC)
Memory: G.Skill - Aegis 16GB (2 x 8GB) DDR4-3000 Memory  ($154.99 @ Newegg Business)
Storage: Crucial - MX500 250GB 2.5" Solid State Drive  ($72.89 @ OutletPC)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($59.69 @ SuperBiiz)
Video Card: MSI - GeForce GTX 1060 6GB 6GB GT OCV1 Video Card  ($294.98 @ Newegg)
Case: Thermaltake - View 21 Tempered Glass Edition ATX Mid Tower Case  ($59.99 @ Amazon)
Power Supply: EVGA - SuperNOVA G3 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($63.98 @ Newegg)
Total: $1075.26
Generated by PCPartPicker 2018-06-05 15:22 EDT-0400
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
https://linustechtips.com/topic/934561-first-pc-build/#findComment-11414441
