im wondering if theres a way to control my laptop's fan speed (because it thermal throttles at times and the fan isnt spinning at its top speed) i already tried cpu-z,gpu-z, fan speed, and msi aftreburner with no luck
if anyone knows a way to control my fan please help me
my harware:
cpu:intel core i3 5005U
ram:12 GB ddr3
gpu:geforce 920m
laptop: asus x540lj (i upgraded the ram from 4GB to 12GB)
https://linustechtips.com/topic/934504-fan-control/
software called speedfan should do.
besides, cpu-z, gpu-z and afterburner arent meant to do this.
Desktop benching:
https://linustechtips.com/topic/934504-fan-control/#findComment-11413571
25 minutes ago, Omarika12 said:
i couldn't get it to work,i looked up vids on youtube and i couldn't get it to work
did you try other chips under configure --> advanced tab?
Desktop benching:
https://linustechtips.com/topic/934504-fan-control/#findComment-11413696
4 minutes ago, Omarika12 said:
yea
out of luck then. Try replacing the thermal paste and cleaning dust away
Desktop benching:
https://linustechtips.com/topic/934504-fan-control/#findComment-11413711
