I just built a new PC today. I've connected all the parts to their respective places and I've also successfully managed to make the cpu run! But when I connect it to the monitor (I've tried both vga and HDMI ports in both the motherboard and the GPU) the monitor is showing 'no signal' now I don't know what to do, I think I've done everything right, if someone would be kind enough to help me, I'd be very greatfull.
Specs (if required)
Msi z370 motherboard
I5 8500
Msi gtx 1050 ti afterburner
8gb ram 2400MHz
2tb Seagate barracuda
Artis 600w psu
https://linustechtips.com/topic/934453-please-help-me-new-pc-problems/
Can you try the monitor on another PC?
Ion (Main Build)        Overall Setup
i5 6500 3.2 GHz        -Blue snowball (White) thanks goodwill
MSI Mortar Arctic        -Logitech K120
Asus 1060 6GB Dual                                                             -Logitech Daedalus Prime G302
PNY CS1311 120 GB                                                            -Mousepad I made in 1st grade with my name on it
WD Caviar Blue 1 TB
Crucial Ballistix Sport LT White 16GB (8x2GB) 2400
NZXT S340 White
Corsair CXM 450W
Lenovo H320 (Old Pre-built PC)                                      Possible upgrade for H320
i5 650 3.2 GHz (heh)        Xeon X3470
Motherboard unknown                                                       Same Motherboard
iGPU        GT 1030 (MSI Low Profile Half Height)
Crucial 240GB SSD                                                           Crucial 240GB SSD
6GB DDR3 (4+2GB)                                                           8-10GB DDR3 (4+2+2GB/4+4+2GB)
Lenovo H320 case                                                             Lenovo H320 case
Unknown PSU (210W?)                                                     Same PSU (210W?)
My z370 won't output display to either its own ports or the GPU unless there's a cable plugged in on boot. It won't display at all if there isn't. I think that's normal? idk
Main rig: i7 8086K // EVGA Z370 Micro // 16GB Gskill TridentZ 3200Mhz CL14 // Sapphire Pulse RX 7800XT// a variety of noctua cooling // Corsair RM750x v2 //  Fractal Meshify C
Secondary rig: R5 3600 // MSI B450i Gaming Plus // 16GB Gskill FlareX 3200CL14 // MSI GTX 1080ti Gaming X // Cooler Master V650 // Fractal Meshify C
Audio setup: Audient iD4 // Adam A7X // Sennheiser HD 650 // Sennheiser HD 25-II // Audio Technica M50x // Sennheiser Momentum 4
Yup, I have 2 monitors, one new and the other one which I use for my old computer, both the monitors show 'no signal'. They both though work fine for the other (old) cpu
48 minutes ago, Praxis727 said:
also, did you try the ram as well as gpu in different slots.  How many ram sticks do you have.  If 2 then try booting from just one.
I've installed the ram (1x8gb ddr4) in the correct slot according to the manual provided in the motherboard box. I also removed the GPU to check, but every attempt failed, the cpu fans and led run well though
2 hours ago, nikilll_19096 said:
Maybe, but how do we fix that?
Turn it off, plug in HDMI/DP, turn it back on again.
would really help if you could snap a picture and post it so I can see what we are working with here.  When you start it up no picture at all.  Even if it didn't give you video off the card it should have off the onboard.  Tells me it has to be something to do with the ram/cpu/mobo.
 Oops, now it's started fluctuating, I don't know what's happening, I've started doubting the smps now, I think it's the one messing all this us (assumption). Before, the fans and all were running perfectly.
June 5, 2018 at 8_51 pm 2018-06-05 20-53-28.mp4
5 hours ago, Praxis727 said:
anyways, if it is running ok just by itself then it is likely your motherboard or one of your parts is touching the case.  Or there is something making it jump in behind the motherboard like a screw
I'll check the Motherboard, I seem to have over tightened the screws or bad cable management.
Anyway, I've managed to contact a technician with great difficulty (my house is in an isolated place) and he's coming this Sunday, I'll post updates for sure. Thank you very much for helping me. I'm really great full to you guys ❤️
