3 hours ago, LoGiCalDrm said:
You can disable it from Accessibility options. It may still appear in login screen which has it own setting.
I don't want to disable it because when I told my laptop I need it to type. The problem is that it shows up even when I don't click a text box
https://linustechtips.com/topic/934311-keyboard-problem/#findComment-11413992
