Ok so I had both a Titan in my system as well as a 6670 which i was using to mine. I had the drivers for both of them installed which hasn't been a problem. I think the 6670 was being used to play my audio though. I wanted to test two 9800gt's that i had so i took both cards out and put the 9800's in. Then i took them back out after testing and just put the Titan back in because I was done with the 6670. When i rebooted my sound didn't work. So I uninstalled AMD Catalyst and all the drivers for the 6670 and made sure Nvidia's sound drivers were there. I restarted and the sound still doesn't work. So i put the 6670 back in and reinstalled the AMD drivers, still nothing. Took the 6670 back out, uninstalled the AMD drivers, reinstalled the Nvidia drivers, and restarted again. Still no sound. I'm completely lost, anyone have any ideas?
https://linustechtips.com/topic/93431-ive-got-an-audio-problem/
I don't have any experience with routing sound through the gpu. Try uninstalling the amd drivers and taking the 6670 out. Then try installing the realtek (or whatever stock audio solution is on your motherboard) audio drivers for your motherboard via the manufacturers website, then reboot and see how that goes?
CPU: 5930K @ 4.5GHz | GPU: Zotac GTX 980Ti AMP! Extreme edition @ 1503MHz/7400MHz | RAM: 16GB Corsair Dom Plat @ 2667MHz CAS 13 | Motherboard: Asus X99 Sabertooth | Boot Drive: 400GB Intel 750 Series NVMe SSD | PSU: Corsair HX1000i | Monitor: Dell U2713HM 1440p monitor
https://linustechtips.com/topic/93431-ive-got-an-audio-problem/#findComment-1255944
