So I got my Ryzen 3 1200 to 3.8ghz at 1.35v I’m on stock cooling and after 30 mins of running aida64 I got 70c as my max temp I don’t think it would go over this for a while because it hit 70 at 10 mins and had no change for the rest of the test. Is this ok for the cpu? I’ve heard below 75 is fine but there are multiple answers some say under 85 some say 92-95 is the max.
https://linustechtips.com/topic/934028-cpu-temperature/
Perfectly fine.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/934028-cpu-temperature/#findComment-11408824
