My only drive in the system is a WD 1 TB Caviar Blue. It is my C: drive, however somehow I now have a D: drive which is a partition of my drive. This would be okay if it did not show itself as being accessible, along with this windows give me notifications saying that it has low space and click here to free space. There is nothing on the D partition thing and the pop up that is to saves space show 0 bytes to be freed if I run it. Please help me I have not had this issue before.
https://linustechtips.com/topic/933837-d-drive-annoying-help/
8 minutes ago, Slifa said:
It doesn't allow me to and it says oem partition but I swear I do not remember seeing this before.
I just checked and i have 3 partitions on  my C drive, but only one of them has a letter.
Maybe you can rightclick on the partition and then "change drive letter" and then click "remove"
https://linustechtips.com/topic/933837-d-drive-annoying-help/#findComment-11406983
I cant do that but I just looked into it more and saw that I can delete it through diskpart (cmd type thing). However apparently that is where a windows recovery "thing" (lol) is and if I ever need to recover then I may have to buy a recovery disk instead. I am about to give up, oh well
https://linustechtips.com/topic/933837-d-drive-annoying-help/#findComment-11407030
