Hey peeps, I have got :
AMD FX-8350
GTX 750Ti
16GB DDR3
and I have been streaming with hardware encoding with 720p 30fps... this is my current settings on obs...
but I know my CPU can do 1080p 30 fps... but whenever I try to stream using x264 encoder I get lag ingame and sometimes (rarely) frames drop on stream...
I need some help to set up my obs for using x264 properly because I feel I am doing something wrong... this is my current x264 setup... please help
all I want to get is a 60fps stream
https://linustechtips.com/topic/933250-need-help-setting-up-obs/
1 minute ago, Rekt_Knight said:
mostly pubg, h1z1, csgo, dota
how much cpu does the stream use?
and have you tried lowering the settings of the games you're playing?
She/Her
Phone: OnePlus Nord CE 5G | 128GB | 8GB Ram
Main Desktop: Ryzen 5 3600 | GTX 1060 6GB | 32GB Ram
Main Laptop: Acer Aspire V3-771G | Core i7 3612QM | 16GB
CPU sits at 80%
all the settings in game are the lowest possible... because I prefer framerate over resolution
Just now, Rekt_Knight said:
CPU sits at 80%
just when streaming?
can you try using the gpu to encode? or does that make the games unplayable?
She/Her
I am currently using gpu to stream... i shared screenshot on the post but the quality is terrible with 30 fps
oh okay. i must have read over that earlier.
how is 720p 60fps? does that work?
She/Her
when i try to do it on NVENC only dota can be streamed 60 fps
i meant cpu encode at 720p 60fps. does that work?
She/Her
x264 = cpu
nvenc = gpu
60 fps is high task for your hardware, even without streaming I can imagine it drops a lot with those games (pubg, h1zz1)
You still can achieve it if you are using two computers, you can buy cheap computer with at least gtx 750 for nvenc acceleration (that's the cheapest gpu that offers nvenc that I know of)
8 hours ago, Rekt_Knight said:
then the fx-8350 is garbage :(
It was good gaming chip back when it released in 2011. It's still decent gaming chip, but not strong enough to stream and game at the same time.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
