So I finished build my pc now it time to connect all the cables up I’m reading through the manual for my motherboard and all of the fan and aio pumps pins are four bout the cable connect to the individual parts are 3 pins is that okay or did I fuck up???
thank you for the help!!
https://linustechtips.com/topic/931979-cpu-fan-pins/
you can connect 3-pin fans to 4-pin headers and vice versa no problem. Keep in mind 3-pin headers cannot be PWM controlled so the speed is regulated by voltage instead (usually 12v or full speed).
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
https://linustechtips.com/topic/931979-cpu-fan-pins/#findComment-11389951
Most motherboards with 4-pin (PWM) also support 3-pin control (linear DC), check manual for any needed BIOS settings on that. If not supported, the fans will still work but without adjustable speed, so 100%. This applies to using 3-pin fans/pumps on 4-pin headers, which will plug right in.
CPU: AMD Sempron 2400+ / MOBO: Abit NF7-S2G / GPU: WinFast A180BT 64MB / RAM: Mushkin DDR333 256MBx2 / HDD: Seagate Barracuda 7200RPM 120GB
https://linustechtips.com/topic/931979-cpu-fan-pins/#findComment-11389955
So plug them in it just I can’t change the speeds manually basically??
https://linustechtips.com/topic/931979-cpu-fan-pins/#findComment-11389976
If the motherboard doesn't support linear DC control then yes. The motherboard having 4-pin headers doesn't mean it doesn't also support 3-pin DC control though. Refer to motherboard manual for that.
https://linustechtips.com/topic/931979-cpu-fan-pins/#findComment-11389986
3-pin fans are speed adjustable. All of my case fans are 3-pin and they can vary in speed. The problem is that they're voltage controlled and the motors need a minimum amount of voltage to even spin. So this limits the minimum speed to about 50%. However, whether motherboards can adjust 3-pin fan speeds or not is another thing (I'm pretty sure most do unless it's a super budget board and they want to pinch pennies off digipots).
https://linustechtips.com/topic/931979-cpu-fan-pins/#findComment-11390078
