Micro cluster S.C.
Restrictions:
1. cannot go over 300 watts
2. cannot go over 650 us dollars
3. Requires a class 10 micro SD card
Project Type: Cluster Computing
Project Goals: Able to mine, and or tied into the folding research S.C. network.
NOTE:Listing Some specs (not all details listed on this forum post for MOBO if you want full features/description link here:http://www.friendlyarm.com/index.php?route=product/product&product_id=206 ))
MOBO Specs:
Name: NanoPi Fire3-LTS
On-board Memory: 1GB
ToM: DDR3
  • Cpu type: ARM OCTA-core cortex A53
  • Core Count: 8
  • Clock Speed 1.2Ghz-(1.3-1.6Ghz potential OC) (NOTE: im taking a rough guesstimate regarding the clock speed)
Amps: 400Ma-1.2A
volts: 5
watts: 6
Price: $35 U.S. Dollars
requires heat-sink? YES
Type of cooling: Water
Passive or active: Active
Parts list In table format:
Total amount of Cpu cores: 56
Total amount of shared RAM: 7gb ddr3
Total amount of shared Disk space: 56 Gb
Theoretical hash speed: 215H/s (non OC) (OC hash rate: unknown needs to be tested...)
Estimated watts: 60
If anyone has any suggestions to help lower the price please edit the excel file attached
Micro Super computer cluster Mk1.xlsx
https://linustechtips.com/topic/931512-project-sc-mini/
