I don't know if this is the right place to post this, but I'm desperate.
I just build my first pc and everything works fine, but my 1TB Seagate Barracuda HDD doesn't show up in windows (10). It shows up in BIO and in "device manager", but not in "devices and drives" nor "disk management". I've tried swithcing the sata cables, updating the drivers, different programs. Nothing worked and now I'm desperat, please help.
Thank you
EDIT: Guys, the drive doesn't show up in "disk manager"
picture:
https://linustechtips.com/topic/931366-help/
Disk Manager> you will see a large black bar saying unallocated > right click it and set a new volume
https://linustechtips.com/topic/931366-help/#findComment-11384262
Yeah like the above posts said, go to Disk Manager.
Right click the big black "Unallocated Space" and create a new simple volume.
Then go through the wizard and use NTFS, Default allocation size, quick format ON, use any name you want ex. DATA.
If it asks you to initialize the disk or says that it is not initialized, initialize it as GPT (GUID Partition Table).
PC:
AMD Ryzen 9 5900X | AMD Radeon RX 7900 GRE | 32 GB RAM | Arch Linux
Laptop:
MacBook Pro 13" (2019) | Intel Core i5 8279U | 8 GB RAM | macOS
Server:
Intel Core i7 6700K | 16 GB RAM | 2 TB HDD | Debian Linux
https://linustechtips.com/topic/931366-help/#findComment-11384263
Get in gparted live, create a partition table (use GPT) and format as NTFS.
There are 10 types of people in this world. Those that understand binary and those that don't.
Current Rig (Dominator II): 8GB Corsair Vengeance LPX DDR4 3133 C15, AMD Ryzen 3 1200 at 4GHz, Coolermaster MasterLiquid Lite 120, ASRock B450M Pro4, AMD R9 280X, 120GB TCSunBow SSD, 3TB Seagate ST3000DM001-9YN166 HSD, Corsair CX750M Grey Label, Windows 10 Pro, 2x CoolerMaster MasterFan Pro 120, Thermaltake Versa H18 Tempered Glass.
Previous Rig (Black Magic): 8GB DDR3 1600, AMD FX6300 OC'd to 4.5GHz, Zalman CNPS5X Performa, Asus M5A78L-M PLUS /USB3, GTX 950 SC (former, it blew my PCIe lane so now on mobo graphics which is Radeon HD 3000 Series), 1TB Samsung Spinpoint F3 7200RPM HDD, 3TB Seagate ST3000DM001-9YN166 HDD (secondary), Corsair CX750M, Windows 8.1 Pro, 2x 120mm Red LED fans, Deepcool SMARTER case
My secondary rig (The Oldie): 4GB DDR2 800, Intel Core 2 Duo E8400 @ 3GHz, Stock Dell Cooler, Foxconn 0RY007, AMD Radeon HD 5450, 250GB Samsung Spinpoint 7200RPM HDD, Antec HCG 400M 400W Semi Modular PSU, Windows 8.1 Pro, 80mm Cooler Master fan, Dell Inspiron 530 Case modded for better cable management. UPDATE: SPECS UPGRADED DUE TO CASEMOD, 8GB DDR2 800, AMD Phenom X4 9650, Zalman CNPS5X Performa, Biostar GF8200C M2+, AMD Radeon HD 7450 GDDR5 edition, Samsung Spinpoint 250GB 7200RPM HDD, Antec HCG 400M 400W Semi Modular PSU, Windows 8.1 Pro, 80mm Cooler Master fan, Dell Inspiron 530 Case modded for better cable management and support for non Dell boards.
Retired/Dead Rigs: The OG (retired) (First ever PC I used at 3 years old back in 2005) Current Specs: 2GB DDR2, Pentium M 770 @ 2.13GHz, 60GB IDE laptop HDD, ZorinOS 12 Ultimate x86. Originally 512mb DDR2, Pentium M 740 @ 1.73GHzm 60GB IDE laptop HDD and single boot XP Pro. The Craptop (dead), 2gb DDR3, Celeron n2840 @ 2.1GHz, 50GB eMMC chip, Windows 10 Pro. Nightrider (dead and cannibalized for Dominator II): Ryzen 3 1200, Gigabyte A320M HD2, 8GB DDR4, XFX Ghost Core Radeon HD 7770, 1TB Samsung Spinpoint F3 (2010), 3TB Seagate Barracuda, Corsair CX750M Green, Deepcool SMARTER, Windows 10 Home.
https://linustechtips.com/topic/931366-help/#findComment-11384287
Go to Control panel, Click on Administration icon, and then Management tool. scroll down to storage. You will see a blank drive. Right click on that drive mount it and then format it
Michael Summers
CaseObsidian 900D  MOBORampage IV Extreme CPU:  i7-4960X Ivy Bridge-E 3.6GHz  RAM:: Vengeance Pro 32GB  Boot : RAID 0  840 Pro  512GB  Data:  RAID 10 WD Red  2TB PS: Corsair : AX1200 GPU:  ASUS  GTX-780 Ti
Birthday Gift from my wife - She made me order it and built it :-)
https://linustechtips.com/topic/931366-help/#findComment-11384658
Video version
Mount Drive.mp4
Michael Summers
https://linustechtips.com/topic/931366-help/#findComment-11384743
