Hi guys, I need your advice, I'm about to buy a new headset mostly to watch movies and music mostly and for gaming ( pc and ps4, so it needs to be compatible with ps4 and needs to have a mic), the headset needs to connect to my tv and my android box to see the movies ( maybe trough usb?) and also I dont know if the 7.1 virtual surround is worth it.
My price limit is 200 $, I saw some reviews and search through forums and two of them caught my attention ( Steelseries Arctis 7 and Hyperx Cloud flight), the arctis 7 sounds nice but on the ps4 the 7.1 is not compatible and it lacks some Bass aparently, the Hyperx cloud flight sounds awesome in every aspects but doenst have 7.1.
Do you guys have other options ? Is it really worth to go for the 7.1 sound? because I want to get a good quality audio mostly on movies.
Thanks in advance.
https://linustechtips.com/topic/931344-wireless-headset/
9 minutes ago, Bcat00 said:
Not sure if you like it but i'm using the corsair void wireless model.
Works for everything that you mentioned but there are cons to it for the cheap price point.
I had seen the Corsair void, but its sounds Bulky and the micro doesnt detatch
https://linustechtips.com/topic/931344-wireless-headset/#findComment-11384123
8 hours ago, bonezz said:
Beyerdynamic custom one pro
anything from beyerdynamic is better than any gaming headset. nuff said.
CPU: 8600k @4.9  (1.39v) |  Cooler: NH-U14s | Mobo: Asus Strix z390i | Ram: Gskill DDR4 Trident Z 3600 8GB x 2 16-16-16-36
GPU: Gigabyte G1 1080 GTX | Case: Prodigy ITX | Fans: NH-A14, (exhaust) NH-A12, (intake) NH-A20 (intake)
Samsung EVO 1tb | Samsung EVO 512gb x2 | Intel ssd 128gb
PSU: Powerstation 500W
https://linustechtips.com/topic/931344-wireless-headset/#findComment-11385863
What are ur toughts on buying a audio - technica mx40 with an microphone and a Bluetooth adapter to become wireless. I am uncertain of my choice, arctis 7 are Nice because are flexible in all the aspects, but the sound its not the best compared to a music headphones. In your opinion what my Best choice and if u can tell me the best music headphone  including microphone and possibly a Bluetooth adapter to fit in my 200 budget, thanks once again
https://linustechtips.com/topic/931344-wireless-headset/#findComment-11388379
