So for the summer I am moving away from home and leaving my desktop PC. So I need a laptop. The problem is that I dont know if I need a gaming laptop or a ultrabook. In the summer I would like to do some occasional gaming, but mostly plan to use the laptop for the internet, making websites. So I have narrowed my choice down to 2 laptops
Alienware 15 R3:
https://www.lmt.lv/lv/dators/DELL_Alienware_15_R3
Dell XPS 15:
https://www.lmt.lv/lv/dators/DELL_XPS_15_9560_Touch
https://linustechtips.com/topic/930476-need-help-choosing-laptop/
Alienware 15 R3:
Dell XPS 15:
If you can afford it, then go for the 1070 laptop.
With the 1070 laptop you can get around 100-120 fps in most games at 1080p ultra settings.
With the 1050 you can get around 60 FPS with Medium settings
Alienware 15 R3:
Dell XPS 15:
Get the alien ware laptop. It will be faster, but make sure to get a laptop bag to put it in. Otherwise you'll look weird carrying a huge laptop around.
Why not AW15 R5?
You can consider thin and light gaming laptops, though most of them don't have good battery life (if that's important)
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
12 hours ago, ZM Fong said:
Why not AW15 R5?
I think I want an ultrabook more but I'm stuck between these 2 because the dell XPS has lower specs but the zenbook pro  has good specs but bad thermals based on what I have seen online and the dell xps 15 has a really good display 4k touch
XPS 15
ZenBook Pro:
https://www.lmt.lv/lv/dators/ASUS_ZenBook_Pro_UX550VE
23 minutes ago, Kunker_ said:
Both have cooling related issues
Budget? Usage? Requirements?
Desktop specs:
Under 3K usd. Making websites writing blog posts and some gaming. I want it to have a good screen preferably bezeless 4k and touch and good gpu 1050 ti upwards and thin/light
touch
Is touchscreen really necessary to you? This will heavily limit your options
Desktop specs:
Any links of online stores in your country?
Desktop specs:
I couldn't find a laptop that can meet ALL your requirements and budget. Could you cut down some requirements? Also, is battery life important to you?
Desktop specs:
Do you think the XPS 15 is a bad choice? Overpriced?
Alright use these 3 shops:
Lmt.lv
Bite.lv
Tele2.lv
What I want:
A good screen (Resolution)
Lightweight (Not over 3kg)
decent gaming performance 1080p@60 or min 1080@45
Battery life at minimum 4 hours
It's good, but not great. Slightly overpriced IMO
What I want:
If you really need a high reso display, looks like Dell XPS 15 9560 is the only option in your country. It needs a lot of tuning and modding.
Try to find Dell 7567/7577 with UHD panel. Alternatively you can go for eGPU solution
Desktop specs:
Lmt.lv
Bite.lv
Tele2.lv
What I want:
its going to be hard to find a laptop that has 4 hours on screen and can play games at 1080@60
