the first monitor is the LG  24MP58VQ-P witch has an ips pannel and 5ms response time aand a 16ms input lag
the second one is The benq GW2470ML Witch has a VA Panel and a 4ms response time and i cant fine any info about the input lag " if some one could tell me , it would be cool "
so i will be using the monitor for gaming .. witch one should i go with ?
https://linustechtips.com/topic/930448-i-need-help-choosing-from-two-monitors/
Do you do any grading or photo editing? If not then the BenQ with a VA panel is probably better with the lower response and lower cost, too.
But if you really care about colour accuracy, go for the IPS one but the downside with that is the higher latency (which you will probably not even notice unless you are playing super competitive multiplayer games seriously such as CS:GO).
May I suggest also something like the AOC G2460VQ6 instead as this has 1ms response, is around the same price, although will suck at colour accuracy as it is a TN panel if that is your buying spec.
can you find the benQ's input lag ? i cant find it anywhere if its lower than 16ms i will go with it other than that i dont mind the extra 1ms in the response time .. and there is only samsung , asus , benq and lg monitors where i live
