PSU fan replacement
Solved by Stefan Payne,
1 hour ago, Blazth said:Ok I'll cancel my order in a sec but can you recommend me to buy an another quieter "suitable for the job" one? I still want to do it.. I can provide the exact model of the fan and the rpm of it.. Just neet to disassemble it once more.
Where do you live, what's available?
The usual stuff would be:
be quiet Pure Power 500W
Bitfenix Formula 550W
Cougar GX-F 550W
Bitfenix Whisper M 550W
Sorted by price and quality. The upper ones should be less expensive - if not, get the next one...
