Just make sure you read up on every part and fully understand what you are doing. Things like tightening, and not over tightening, compression fittings, thermal paste applications, etc... Also, plan on doing a 24 hour leak test. This means nothing else is powered on bu your pump, you prime you system up and then let it run, just the pump, for 24 hours, making sure there are zero leaks.
And above all, when in doubt, ask questions. :)
I understand that fully, thank all of you so much for the great help, I'll be building this next winter ( this stuff is expensive ) ill be posting in the next months in the build logs. I'm also using a non-conductive liquid so in case of any spill I'm still safe hopefully.
Project Casper - Glass Tubing Build
Ryzen 9 5905x     |    Gigabyte Aorus Extreme X570    |   Strix 3090
GSkill 64gb 4000mhz   |    EVGA 1600T psu     |      3x Samsung 980 Pro NVME 1tb Raid 0
  4 x Crucial MX500 2tb raid 0   |    Glass Hard Line Tubing  - EKWB Blocks
https://linustechtips.com/topic/9299-water-cooling/page/2/#findComment-104489
Sorry - there is no such thing as a non-conductive liquid. :) Some people think using deionized water will solve this, but it doesn't. As soon as you open the container, free ions start saturating your solution. And, simply running it through your loop and the metal components ensures it will not be deionized for very long at all. Hence, why the 24 hr leak test. If you have a leak when everything is on, odds are you will fry something if it hits a critical component.
Forum Links - Community Standards, Privacy Policy, FAQ, Features Suggestions, Bug and Issues.
Folding/Boinc Info - Check out the Folding and Boinc Section, read the Folding Install thread and the Folding FAQ. Info on Boinc is here. Don't forget to join team 223518. Check out other users Folding Rigs for ideas. Don't forget to follow the @LTTCompute for updates and other random posts about the various teams.
Follow me on Twitter for updates @Whaler_99
https://linustechtips.com/topic/9299-water-cooling/page/2/#findComment-104711
Ok ya I know nothing is perfect but I'm looking a pre mixed coolent so I don't have to worry about alge growing.
https://linustechtips.com/topic/9299-water-cooling/page/2/#findComment-104851
That is typically the easiest option. I use premix myself...
https://linustechtips.com/topic/9299-water-cooling/page/2/#findComment-104939
