My brother gave me his setup with had a broken motherboard which he believes maybe overvolted or messed up the other parts. I changed the GPU and the motherboard and next week the CPU cooler is coming. The status lights are not saying the ram is not working and i have it on the ddr4-2 which i believe is the right spot and the gpu status light sometimes flashes then turns off the system so its an overall mess :(((
https://linustechtips.com/topic/929819-help-asap/
Try DDR4_1 instead of 2. Remove the GPU and HDD. See if it POSTs or boots to the BIOS.
https://linustechtips.com/topic/929819-help-asap/#findComment-11369017
52 minutes ago, hconverse02 said:
Can you give us parts and what is/isn't working? I dont recommend trying to boot until you have a cooler
gpu gtx 1050 ti and the ram is drr4 single 8gb and motherbaord is b250 Lg something and the hdd is 2tb and the power supply is 650 80 gold plus
https://linustechtips.com/topic/929819-help-asap/#findComment-11369170
