http://www.trustedreviews.com/reviews/razer-blade-15
https://www.windowscentral.com/razer-blade-15-hands-on
https://www.theverge.com/circuitbreaker/2018/5/22/17378790/razer-blade-2018-update-bezels-15-inch-display-gaming-laptop-nvidia-max-q-redesign-intel
Quote
The first thing fans of the Blade will notice is the display. It's now larger but has seriously skinny side-bezels. As such, the whole footprint of the Blade 15 is just 10mm wider than the current 14-inch model.
For 2018 the display has been bumped up to 15.6-inches and it comes in three different variants. The entry-level Blade 15 will have a 1080p, non-touch, 60Hz display. The most expensive model will have a 4K 60Hz touch display. But for gamers, the sweet spot is right in the middle.
Razer has included a 1080p 144Hz display on the latest Blade and at first glance it's superb. You're getting 100% sRGB support, so it looks good, and thanks to that fast refresh rate you'll be gaming like you've never gamed before on a Blade.
Some thoughts on the new Blade
https://www.razer.com/ca-en/gaming-laptops/razer-blade
Pros:
  • Got rid of Killer (bless the lord)
  • Gave us back non-soldered RAM (did NOT see this coming, someone smacked somebody on the Blade team)
  • Vapor chamber full cover heatsink (this is nice)
  • Webcam on TOP (copy this XPS15)
  • Finally stopped using the cancer HDT heatsinks
Cons:
  • Oh fucking dear lord Razer's history of QC makes me terrified of their heatsink construction
  • Could end up like the Razer Blade Pro vapor chamber disaster
  • The fins look tiny compared to what they want to put in
  • 1070 Max Q seems like a bad idea without a full LM mod (even then still looks like a terrible idea)
  • It is going to be power throttled as FUCK on the 1070 one, I can feel it already. 200w power adapter tells me they went the Aorus X5 MD way of saying fuck you power, smaller brick is better.
Image result for razer blade 15
Edited by Pendragon
non-soldered ram
Laptop Main
(Retired) Zbook 15: i7-6820HQ, M2000M, 32gb, 512gb SSD + 2tb HDD, 4k Dreamcolor
(Retired) Alienware 15 R3: i7-6820HK, GTX1070, 16gb, 512 SSD + 1tb HDD, 1080p
(Retired) T560: i7-6600U, HD520, 16gb, 512gb SSD, 1620p
(Retired) P650RS: i7-6820HK, 1070, 16gb, 512gb + 1tb HDD, 4k Samsung PLS
(Retired) MBP 2012 Retina: i7-3820QM, GT650M, 16gb, 512gb SSD, 1800p
https://linustechtips.com/topic/929611-razer-blade-15-released/
Ahh duplicate. Please delete. Didn't see.
Laptop Main
https://linustechtips.com/topic/929611-razer-blade-15-released/#findComment-11366935
1 hour ago, mynameisjuan said:
how is soldered RAM a pro
he edited. also, where did my previous post go?
Bethesda PC:   R7 3700X  -  Asrock B550 Extreme 4  -  Corsair Dominator Platinum RGB 16GB@3.6GHz -  Zotac AMP Extreme 1080TI -  Samsung 860 Evo 256GB  -  WD Blue 2TB SSD -  500DX  -  Stock cooling lul  -  Rm650x
CrumpleBox V3:  Xeon X5680  -  Asus X58 Sabertooth  -  DDr3 16GB@1.33Ghz  -  Gigabyte 1660s -  TT smart RGB 700W  -
Cooler Master Storm Trooper  -  120GB Samsung 850 Pro   -  LTT Edition Chromax NH-D15 ?
CrumpleBox 3 ROTF: I5-6400  -  MSI B150m Mortar  -  16GB 2133Mhz Vengeance Pro RGB  -  Strix 1070Ti - GTX 1070 FE  -  Adata 128GB SSD  -  Fractal Design Define C  -  Gammaxx 400V2  -  Cooler Master silent pro gold 1000W
CrumpleBox 2: i7-7820x - MSI X299 Raider - 32GB Thermaltake Toughram 3.6Ghz - 2x Sapphire Nitro Fury - 128GB PCie Adata SSD - O11 Dynamic - EVGA CLC 360 - Corsair RM1000X
Perhiperals:  Gateway 900p60 monitor  -  Dell 1024x768@75  -  Logi. G403 Carbon  -  Logi. G502  -  SteSer. Arctis 5  -  SteSer. Rival 110 - Corsair Strafe RGB MK.2
https://linustechtips.com/topic/929611-razer-blade-15-released/#findComment-11366972
-= Locked =-
As stated this has been posted before.
 CHRISTIAN MEMBER
https://linustechtips.com/topic/929611-razer-blade-15-released/#findComment-11367040
Guest
