Dual Channel RAM problem
Go to solution Solved by BlueChinchillaEatingDorito,
28 minutes ago, elmasbarbo88 said:
I have one Gskill Ripjaws V 8 GB 2400 MHz in my motherboard. If I buy this RAM's 4GB model , are they working dual channel? Thank you for comments.
No because for dual channel operation, both sticks need to be of the same size as well as timings.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
No, Dual Channel works even if they're different sizes. Timings and Speeds are adjusted by BIOS accordingly. Just tried it yesterday, can confirm it works.
CPU: i5-8400 |  CPU COOLER: Cryorig H7 QUAD LUMI | MOBO: Gigabyte Z370M D3H RAM:  16gb Corsair Vengeance RGB 3200mhz CL15 |
GPU: Zotac GTX 1070 Mini @ +180/400 | Storage: Samsung 850 EVO 250gb, Western Digital Blue 2TB, Western Digital Green 1TB | Monitor: ViewSonic XG2401 144hz | Keyboard:  Corsair K70 Cherry MX RED Mouse: Zowie EC1-A
Your BIOS essentially just set itself to run at the lower speed in order for it still work. It doesn't mean it is running in proper dual channel operation; rather, it's just running in single channel mode. So it will still POST and work, but you will not be gaining the benefits of dual channel, which makes finding the matching memory brand and series a wasted effort.
Excerpt from Intel page on Single and multichannel memory modes.
Rules to enable dual-channel mode
To achieve dual-channel mode, the following conditions must be met:
  • Same memory size. Examples: 1 GB, 2 GB, 4 GB.
  • Matched DIMM configuration in each channel.
  • Matched in symmetrical memory slots.
Configurations that do not match the above conditions revert to single-channel mode. The following conditions do not need to be met:
  • Same brand
  • Same timing specifications
  • Same speed (MHz)
The slowest DIMM module populated in the system decides memory channel speed.
Source: https://www.intel.com/content/www/us/en/support/articles/000005657/boards-and-kits.html
  • Same brand
  • Same speed (MHz)
That's weird, I did a test yesterday if I needed more ram or not to reduce my microstutters and I did manually set my speed and timings. CPU-Z detected that my dimms were in Dual Channel. Benchmarks (latency most importantly) and performance were significantly better.
Thread is here.
Could be case to case basis since we've come so far in terms tech. Not if there's any technological limitations that I'm not aware of.
