So I got pretty much everything for my build except RAM and CPU cooler
I decided to get RAM first and for no reason I decided to take a look at ASRock's b250 pro4 supported RAM list and I couldn't find the one I want (Trident Z).
My question is if I buy it will there no problem or will it end up with money down the drain?
https://linustechtips.com/topic/928349-asrock-ram-problem/
Most RAM out there is already made primarily for Intel chipset mobo. You most likely will not have any issue I would say less than a 5% chance of not working.
PSU Tier Ranking List
Ryzen 5 1600x|ASROCK                      |16GB DDR4 3400Mhz Corsair Vengence   | (partial build in progress)
FX-8350 AM3+| ASUS M5A990FX V1 | 32GB DDR3 2400Mhz Corsair Vengeance | Samsung EVO 850 PRO | Win 7 64 Pro | EVGA 750W G PSU | EVGA 750 ti 6GB | Corsair H100i v1
FX-8120 AM3+| ASUS M5A990FX V2 | 16GB DDR3 2400Mhz Corsair Vengeance | Samsung EVO 850 PRO | Win 7 64 Pro | EVGA 750W G PSU | EVGA 750 ti 6GB | Corsair H80i v1
I5-2500K LGA  | ACER MOBO??         | 16GB DDR3 2400Mhz Corsair Vengeance | Samsung EVO 860 PRO | Win 10 64 Pro | EVGA 750W G PSU | EVGA 970 SC 4GB | Corsair H80i v1
https://linustechtips.com/topic/928349-asrock-ram-problem/#findComment-11356152
From the manufacturer's specs list...
  • Supports DDR4 2400 (Intel® 7th Gen CPUs) / 2133 (Intel® 6th Gen CPUs)
I think it should work but the speed of it will decrease to fit the needs of the mobo.
"May your frame rates be high and your temperatures low"
I misread titles/posts way too often--correct me if I don't.
https://linustechtips.com/topic/928349-asrock-ram-problem/#findComment-11356153
