Parts Tips?
Go to solution Solved by Herman Mcpootis,
CPU: Intel - Core i5-8400 2.8GHz 6-Core Processor  ($178.89 @ OutletPC)
Motherboard: Gigabyte - B360M DS3H Micro ATX LGA1151 Motherboard  ($65.99 @ SuperBiiz)
Memory: Team - Dark 16GB (2 x 8GB) DDR4-3000 Memory  ($159.99 @ Newegg)
Storage: Crucial - MX500 250GB 2.5" Solid State Drive  ($72.89 @ OutletPC)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($43.09 @ SuperBiiz)
Video Card: MSI - GeForce GTX 1060 6GB 6GB Video Card  ($284.98 @ Newegg)
Case: Thermaltake - Versa H18 MicroATX Mini Tower Case  ($49.99 @ Walmart)
Power Supply: Cooler Master - MasterWatt 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($31.65 @ Newegg)
Total: $887.47
Generated by PCPartPicker 2018-05-18 09:48 EDT-0400
cheaper 550w psu, case, and get an 8700+ stock cooler and B360 board or i5 8400 instead.
https://linustechtips.com/topic/928231-parts-tips/#findComment-11355014
Total: $887.47
https://linustechtips.com/topic/928231-parts-tips/#findComment-11355018
Total: $887.47
I didnt know a 360 board would work with coffee lake. Whats the difference between a 360 and 370 board then?
https://linustechtips.com/topic/928231-parts-tips/#findComment-11355027
a few less features and no overclocking.
https://linustechtips.com/topic/928231-parts-tips/#findComment-11355037
https://pcpartpicker.com/list/kKNd9J
if you spend a bit more money, this is much better for gaming
https://linustechtips.com/topic/928231-parts-tips/#findComment-11355038
You can overclock the overclockable K CPUs like the i7 8700k on z370 boards, B360 boards are for the non K CPUs like the i7 8700
RGB & Fan control ULTIMATE GUIDE !
https://linustechtips.com/topic/928231-parts-tips/#findComment-11355039
1 hour ago, KingLuvely said:
So new build coming up, this is what I have right now. I plan on using it for gaming and everyday use. Any ideas on potential price lowering without sacrificing performance in gaming? (I already have Hard drives)
https://pcpartpicker.com/user/KingLuvely/saved/#view=M8tvVn
Get something like this....way better...
Motherboard: ASRock - B360M Pro4 Micro ATX LGA1151 Motherboard  ($69.99 @ Newegg)
Memory: Team - Vulcan 16GB (2 x 8GB) DDR4-3000 Memory  ($159.99 @ Newegg)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($59.79 @ OutletPC)
Video Card: Asus - GeForce GTX 1060 6GB 6GB Dual Video Card  ($289.98 @ Newegg)
Case: Cooler Master - MasterBox Q300L MicroATX Mini Tower Case  ($36.99 @ SuperBiiz)
Power Supply: EVGA - SuperNOVA G3 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($69.99 @ Amazon)
Total: $938.51
Generated by PCPartPicker 2018-05-18 11:06 EDT-0400
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
https://linustechtips.com/topic/928231-parts-tips/#findComment-11355212
