When I connect monitor to onboard VGA it doesn't work properly, can not set it on NATIVE RESOLUTION, it shows many other resolutions.
I can only set it on Native resolution when I connect monitor to GPU, GPU sees the correct resolution but onboard graphics doesn't.
What can be the problem here?
The GPU somehow manages to use native res but onboard graphics doesn't while other monitors work properly on onboard VGA....
Laptop: Sony Vaio E17 i7-3632QM // HD 7650M
Monitor: Asus Designo MX239H // TX-58DXR800 4K
Storage: SanDisk Extreme PRO, WD Black 500GB
Sound: Asus Xonar U7 MKII // Logitech Z906 5.1 THX
Mobile: Google Pixel 7
https://linustechtips.com/topic/927602-native-resolution-problem/
When you're connected to your onboard video, do you see Windows Basic Display Adapter in Device Manager? If so, you don't have drivers installed for your onboard graphics.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
It doesn't work with or without drivers, but works good on other monitors.
This monitor has some problem with onboard VGA but it works properly on GPU...
