Hi tech experts,
Building a new computer that I want to run EYEFINITY. Wondering if more cores helps with gaming performace (Crysis 3)
AMD FX8350 vs Intel 3570K
No idea if more cores helps with eyefinity performance,
Probably will get the Asus 3gb Radeon 7950
Also I need reliability...I want to do uni work on the PC so I need it to not break down.
Dunno if this info will help:
I want to raid 1(identical) 2 x 128gb ssds. Question, do they have to be the same ssd (or can one be intel and the other samsung)?
may use the pc for up to 15 hours a day, sometimes I leave it overnight.
Thanks in advanced, babes.
https://linustechtips.com/topic/9273-cpus-for-eyefinity/
Right now you're not going to see any cost effective difference by running more than 4 cores. For a multimonitor display setup, you really want maximum GPU power and VRAM. Having hyperthreading or 4+ cores won't improve your performance if your GPU isn't up to par.
If you plan to run 3 monitors @ 1080p to play Crysis 3 on a single GPU, you will have to sacrifice the fancy stuff like AA.
https://linustechtips.com/topic/9273-cpus-for-eyefinity/#findComment-101883
Intel CPUs are very rock solid and reliable, Not that AMD's cpu's are bad. But as a consumer I trust my money more with Intel, and my 3570k overclocks like a beast! Either will work but if you are looking for rock solid reliability i'd say intel.
[9:01:47 PM] Slick: And the award for life time acheivement in the field of "maker of the least amount of sense" goes to Kilmer.
https://linustechtips.com/topic/9273-cpus-for-eyefinity/#findComment-102272
Well, I believe that even with two HD7950's in CF mode doing EF @5760x1080, GPU bottleneck is more of a real issue than CPU bottleneck. IMHO, the GPU(s) would prolly be the limiting factor here since it (they) has to cope with rendering three times the usual number of pixels. For example, if the CPU is capable of , say, calculating physics and AI and pumping out, a theoretical 100fps,while the GPU is capable of, say, 125fps, you would get 100fps since the CPU is the bottleneck. But, if the GPU is required to render 5760x1080, it can, perhaps, render 50fps, while the CPU can do a theoretical 75fps (due to more overheads, perhaps more physics and AI due to wider frame), you'd get only 50fps since the GPU is the limiting factor. This is how I think of it anyway, someone correct me if I'm so wrong....:o
I have a 3960X @4.5ghz + 3x HD7970's, and @5760x1200, max ingame for BF3, I suspect it's my vid cards that is the limiting factor.....ceteris paribus,my CPU may as well be an FX8350, I believe the framerate would be quite similar. Again, this is just my impression, opinion.....don't quote me on it!:eek:
 Main Rig: AMD AM4 R7 5700X3D (8C/16T) + TR Phantom Spirit 120 EVO | Gigabyte X570 Aorus Xtreme | 2x 16GB Kingston Fury Beast DDR4 3600 | XFX MERC 310 RX 7900 XTX | 256GB Sabrent Rocket NVMe M.2 PCIe Gen 3.0 (OS) | 4TB Crucial P310 NVMe M.2 PCIe4x4 | 2TB TG Cardea Zero Z440 NVMe M.2 PCIe Gen4x4 | 4TB Samsung 860 EVO SATA SSD | 2TB Samsung 860 QVO SATA SSD | 6TB WD Black HDD | CoolerMaster H500M | Corsair HX1000 Platinum | Logitech G915 + G303 Shroud Ed + 8BitDo Ultimate 2.4G | iFi Micro iDSD Black Label | Philips Fidelio B97 | C49HG90DME 49" 32:9 144Hz Freesync 2 | Omnidesk Pro 2020 48" | 64bit Win11 Pro 24H2
2nd Rig: AMD AM4 R9 5900X (12C/24T) + TR PA 120 SE | Gigabyte X570S Aorus Elite AX | 2x 16GB Patriot Viper Elite II DDR4 4000MHz | Sapphire Nitro+ RX 6900 XT | 500GB Crucial P2 Plus NVMe M.2 PCIe Gen 4.0 (OS) | 2TB Adata Legend 850 NVMe M.2 PCIe Gen4x4 |  2TB Kingston NV2 NVMe M.2 PCIe Gen4x4 | 4TB Leven JS600 SATA SSD | 2TB Seagate HDD | Logitech G613 + G703 | SOLDAM XR-1 Black Knight | Enermax MAXREVO 1500 | 64bit Win11 Pro 24H2
HTPC: AMD R7 6800H | 32GB DDR5 4800MHz | AMD 680M iGPU | 2TB SSD (2 Partitions 400GB + 1.4TB)) + 1TB SSD | Logitech G613 + G304 | Win11 Pro  24H2
Laptop: Lenovo Legion 5 Pro 16ACH6H - AMD 5800H | 32GB DDR4 3200MHz | 680M iGPU | 1TB Kingston NV1 NVMe M.2 (OS) | 4TB Lexar NM790 SSD | Win11 Pro
https://linustechtips.com/topic/9273-cpus-for-eyefinity/#findComment-102577
