I’m trying to make a Gaming Battlestation that can play games at 1440p high for the next 3 to 4 years. I want to also do some basic content creation and coding on it. I have around $1500 USD to spend. My PCPartpicker list is linked below.
https://pcpartpicker.com/list/P2RbKB
As you can see I have built it around the Ryzen 5 2600X and GTX 1070ti. Unfortunately, it is 250 dollars over budget.  If anyone could help cut it down 250 dollars, that would be great. Also other suggestions(such as better monitors) would be greatly appreciated.
https://linustechtips.com/topic/927056-help-build-overbudget/
Get a cheaper motherboard? that motherboard can go sli so if you are not planning on adding an extra gpu find one that is cheaper without sli support. however this wont save too much money.
also on that link it only says it costs 1550 not 1750?
CPU: i7 8700k Motherboard: MSI Z370 Krait Gaming RAM: 4x 8GB Corsair Vengeance Pro (2 white, 2 black) GPU: MSI RTX 2070 Armor Case: Corsair Crystal 570x White HDD: 2x 2TB Seagate Barracuda 7200rpm Sata 3 SSD: 240GB Corsair Force 3 + 500GB Samsung 970 Evo Cooling: Corsair Hydro Series™ H150i PSU: Corsair RM750i OS: Windows 10 Pro 64-Bit
Mouse: Logitech G600 Keyboard: Corsair K95 RGB Cherry MX Brown Monitor: Samsung S24C570L 1080p 23.6" + AOC AGON 240Hz 1080p Sound: HyperX Cloud Headset Black/Red + Logitech Z213 Speakers 2.1
https://linustechtips.com/topic/927056-help-build-overbudget/#findComment-11343331
You can get windows for free from microsoft's website, and buy a sub key on eBay for around $10. Activate it with the sub key and your good to go. I also suggest using ethernet instead of WiFi. Faster and cheaper. Get rid of the WiFi adapter if it isn't crucial to have.
hi.
https://linustechtips.com/topic/927056-help-build-overbudget/#findComment-11343333
Yes, I saw that too. The link has a 1060 6GB, and the photo has a 1070ti. OP probably got things mixed up :/
hi.
https://linustechtips.com/topic/927056-help-build-overbudget/#findComment-11343337
This.
Didn't know if i was allowed to mention it as its key buying but i would do it and save as much as you can
https://linustechtips.com/topic/927056-help-build-overbudget/#findComment-11343344
I would cut it down to a 1070 non-TI if I was you, since at 1440p it can still handle it ok.
If not that, try cutting your SSD mem in half, and go with 240GB if you can do with it :) You've got the terabyte...
EDIT: yeah that RAM is way over the top, cut back on the RGB
My profile picure is real. That's what I look like in real life. I'm actually a blue and white African Wild Dog.
Ryzen 9 5900X - MSI Ventus 2x OC 3060 Ti - 2x8GB Corsair Vengeance LPX 3200MHz CL16 - ASRock B550 Phantom Gaming ITX/ax
EVGA CLC 280 + 2x140mm NF-A14 - Samsung 850 EVO 500GB + WD Black SN750 1TB - Windows 11/10 - EVGA Supernova G3 1000W
https://linustechtips.com/topic/927056-help-build-overbudget/#findComment-11343350
Thank you for your quick response. I have changed the link to be the list with the 1070ti. The only motherboards that support the 2000 series Ryzen CPUs without bios update are the X470 range, and those motherboards are all $130 or more. So I don't know if I should change the Motherboard.
https://linustechtips.com/topic/927056-help-build-overbudget/#findComment-11343391
Thank you. I will get rid of the PCI-E wifi card and will use Ethernet. Also, do you know if buying a subkey from eBay or another site is actually legitimate because I don't want this computer to fail or have anything go wrong in day to day use?
https://linustechtips.com/topic/927056-help-build-overbudget/#findComment-11343414
fair, if thats the case do as others have suggested in: remove the wireless card, get non rgb ram and what AskTJ said about windows
https://linustechtips.com/topic/927056-help-build-overbudget/#findComment-11343416
25 minutes ago, SethKraota said:
As others have said drop the OS, PCI Wireless card and consider non RGB ram.
Thanks for the suggestions.
https://linustechtips.com/topic/927056-help-build-overbudget/#findComment-11343423
Check out this build: https://pcpartpicker.com/list/8WZKpG
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
https://linustechtips.com/topic/927056-help-build-overbudget/#findComment-11343433
I have changed the link and the picture again to reflect the changes I made. I cut the SSD in half, took out the wifi card, and Changed the RAM. I don't think I should buy an activation key, but if anyone has done this successfully before, I would greatly appreciate you sharing how to. I still need to save 140 USD so I am wondering if I should cut down to a regular 1070 and save $50.
https://linustechtips.com/topic/927056-help-build-overbudget/#findComment-11343454
1 minute ago, Reaper1217 said:
Why do you suggest switching to the 8700? Also, I want at least 23-inch monitors. Thank you for the suggestion though.
If you aren't gonna overclock, the 8700 is better than the 2600x for gaming and maybe even productivity thanks to its higher boost clocks. If you are gonna overclock, the story may change. I just swapped out those monitors to save a total of $40, but if they're too small... swap in the old ones.
https://linustechtips.com/topic/927056-help-build-overbudget/#findComment-11343479
