PC restarting randomly, not psu
3 minutes ago, Rob Walsh said:the only critical in the event viewer is kernal failure.. but there are tons of errors.
my build: - B350F Asus Rog mobo - 2700x @4.01Ghz - 250Gb NvME ssd 960 evo - 2x8Gb DDR4 @3200Mhz - Corsair 750w psu -NZXT S340 - 1TB WD Black HDD - Corsair H100iV2 - XFX R9 390 8Gb -
No, i'm not certain. I thought the paper clip test was just to show if the fan spun up, because if it fan doesnt spin its bad, right? I have troubleshooted the OC that is on it, very mild at 4.0ghz and doesn't get hot at all. I think it started having these problems when my windows usb wasn't full plugged in and was in a usb 3.1 or whatever, it restarted and installed a corrupted version of windows on my pc. I don't know if that correlates any longer however. I use my forward usb thing for charging my vape which pulls a wopping half a watt or something. I tested my fathers r9 280 on it and at the time the amd gpu drivers was what was making it crash and so i had to reinstall them like 3 times a day. Now I don't have any amd drivers on this thing at all, i also have updated my nvme
Sounds like a PSU problem so far, do you have another PSU to test?
