Hi,
I switched between my main monitor (1920x1080 24") and another monitor (1680x1050 22"), but when I plug in the second monitor (system is still on), and change the resolution in settings, it not only appears vv blurry, but about an inch is taken off the top and bottom of the display, hiding the taskbar. The width is correct though? I've tried the monitors auto-adjust but that makes it worse,and the options on the display just move the UI around.
Never encountered this before, despite the fact I switch these monitors frequently...
It's probably a really obvious fix but I've never had this happen before??
Thanks
i7 8700k @ 5.0Ghz | ASUS Strix Z370-F Gaming | Cryorig R1 Ultimate | 16GB Corsair Vengeance LPX DDR4-3000 | ASUS Strix GTX 1080 8GB (A8G) | WD Black 500GB PCIe NVMe | Samsung 750 EVO 120GB | Western Digital Black Series 1TB | Fractal Design Define R6 TG | Corsair RM750x
"Everyone says that I'm incredibly unlucky at the Silicon Lottery. In truth, I just persist in believing that 106°C is an acceptable temperature."
- Me, 2018
https://linustechtips.com/topic/926996-scaling-issues/
