RGB Fan recommendations
FrizL
I pre-ordered the new Lian Li PC011 Dynamic case. I can mount up to 9 120 mm fans and 3 360mm rads. I was looking at getting the Enermax AIO and fan combo to fill all slots. Seems to be an issue with those and Aura sync that i want to use through my Z370-A mobo. I know the Corsair LL fans are absolutely beautiful and efficient but at the price point they better be.
Anyone have thoughts/experience with the Enermax fans and hub? Or recommendations on what I should pick up?
Thanks
1 minute ago, FrizL said:
-SNIP-
For RGB fans that are Aura capable the list is fairly short, one I would recommend would be the Cooler Master units. The Corsair units require their own controller and software via Corsair link so they cannot be synced with the motherboard.
https://www.asus.com/campaign/aura/us/Partners-and-promotions.html
