I tried overclocking my ryzen 3 2200g gfx to 500 instead of 400 and when irestarted my computer it just turned back on and didnt register the overclock but when i tried to apply it again there were errors (all the errors will be in the pictures below)
one of the was windows recovery error and when i tried to click repair it went to a blue screen saying that they shut down the computer as to cause no damage and they said that something was wrong with the bios even though i had the latest version
P.S
i've already reset cmos and tried to change the ram to different slots and even tried to use only one stick of ram
https://linustechtips.com/topic/926411-a-problem-has-been-detected/
Your RAM got changed while going from Hibernation to Awake.
you can use a Windows Install media to access a terminal which you can type:
cd C:/
del hyberfile.sys
and you can reboot.
I would help you more but you didn't say what Windows version you have, e.g. XP, 7 ,10, etc.
My profile picure is real. That's what I look like in real life. I'm actually a blue and white African Wild Dog.
Ryzen 9 5900X - MSI Ventus 2x OC 3060 Ti - 2x8GB Corsair Vengeance LPX 3200MHz CL16 - ASRock B550 Phantom Gaming ITX/ax
EVGA CLC 280 + 2x140mm NF-A14 - Samsung 850 EVO 500GB + WD Black SN750 1TB - Windows 11/10 - EVGA Supernova G3 1000W
cd C:/
del hyberfile.sys
and you can reboot.
Thats pre 10. Probably even pre 8/8.1, ive never seen either 8 or 10 come up with that format of BSOD.
My guess would be windows 7.
QUOTE/TAG ME WHEN RESPONDING
Please Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It. Take Time & Explain
New TOS RUINED the meme that used to be below :(
My guess as well.
16 minutes ago, Hunter343 said:
I have windows 10
Um what?
Did you upgrade or are dual-booting with Windows 7?
2 minutes ago, Hunter343 said:
I have windows 10
How the frick are you getting the OLD BSOD then?????
Make sure you dont have a broken windows media install connected through USB or a disk drive.
Create a Windows 10 Install Media
Boot into it
choose Repair Your Computer in the bottom left corner
Troubleshoot>Advanced Tools>Command Prompt
del hiberfile.sys
15 minutes ago, DaJakerBoss said:
Um what?
even the "Start windows normally" isnt from win 10... Im so confused
As per the microsoft website, as @DaJakerBoss said, it does indeed to look to be a hibernation issue.
Quote
This problem may occur if you add random access memory (RAM) to the computer while it is in hibernation. When the computer resumes from hibernation and loads the Hiberfil.sys file, Microsoft Windows detects the change in memory state, and then you receive the error message.
I do have windows 10 but when this kind of stuff happens idk y but it’s as if I have windows 7 but once it starts up it goes back to windows 10
I didn’t do anything to the ram while it was off it asleep and I don’t have the option to hibernate
But the thing is I can’t access anything other than the bios
so I don’t know how to fix this
Did you upgrade from 7?
I would do a fresh install of windows.
4 minutes ago, Hunter343 said:
Fresh
The thing is I’ve had this pronl m before and I fixed it without anyone’s help but I don’t remember how I did it
If the problem has happened before, its likely going to happen again.
I would do a fresh install.
