Xspc sells some called "radstands" and they cost about $15 a piece on Amazon for the 120mm versions. Not sure if that's what you meant but I wish I had looked that up when my friend and I had built in his htermaltake core p5 lol.
Caselabs also sells some for $12
And after thinking about it some more I'm pretty sure you meant this.
https://linustechtips.com/topic/926154-fan-arm/#findComment-11351162
