This is for maybe innexperienced buyers who aren't sure if there parts are going to work for what they want or if you want people to just review your parts. This is helpful if you want to see if you can get any improvments on your fps like getting the last ounce of fps out of a computer.
Anyway I'll start off and share my build to see if anyone wants to improve it or thinks its a very bad build.
My Newb hackintosh build: http://pcpartpicker.com/p/2pbNT
https://linustechtips.com/topic/92615-build-reviews/
i would go with an high end aircooler or a 240 rad for cooling a 4770k.
and i would not get 16 gb of ram, since 8 is enough for games, unless you render video's. in that case it is fine
Intel 3570k 3,4@4,5 1,12v Scythe Mugen 3 gigabyte 770     MSi z77a GD55    corsair vengeance 8 gb  corsair CX600M Bitfenix Outlaw 4 casefans
https://linustechtips.com/topic/92615-build-reviews/#findComment-1247295
Well if its a hackintosh build then he probably wont be playing many games.
unless the user dual boots.
https://linustechtips.com/topic/92615-build-reviews/#findComment-1247299
if i may ask, what do you need an 4770k for?
Nailed it brah......
FX 6300 @ 4.2 Gigahurtz 1.325V ,  ASRock 970 Extreme 4 mobo  ,  Kingston Hyperx Blu 2X4GB @1600Mhz  , Asus GTX 960 DCU ii Black OC  , Hyper 212 Evo , Samsung 850 Evo 250 GB , WD 1 TB caviar Green , Xonar DG sound card , Seasonic M12ii Evo 620W PSU , Corsair 200R case ,4 random case fans.
https://linustechtips.com/topic/92615-build-reviews/#findComment-1247759
